how can i change the Horn of 2008 Land Rover
you must first check the horn fuse if it is working as replacing the fuse will a money and time saving change
If the fuse is good then the horn has to be changed
Below is the procedure :-
a) First disconnect the ground wire from the battery.
Description of the wire is a black wire extending from the battery to the frame of the vehicle.
B) Second is to locate the car's horn.
Description it is under the hood in one of three places usually:
it could be near the car's battery OR above the left or right wheel-well or near the front grille.
Disconnect the power supply wire from the rear of the horn. Then place it into the replacement horn.
c) Mount the horn to the vehicle.
Description remove and replace the entire mounting bracket. by using a screwdriver (kind varies, usually Phillips). and also you will need to prepare receiving holes for the remounting.
d) To finish the process just reconnect the battery grounding wire and test the horn.
