Massimo Posted November 17, 2013 Report Share Posted November 17, 2013 Hi Forum My Airbag warning light is on because of a faulty airbag trigger unit. Do I need to fix immediately, is it dangerous? Thank you! Link to comment Share on other sites More sharing options...
sidhh Posted January 6, 2014 Report Share Posted January 6, 2014 Well if light is one, then that means that SRS system is having some fault somewhere. However its seriousness will be known after getting the proper diagnostic with LR scanner. From safety point yes its serious, but from driving point it is not, and it doesn't affect other part of car. There are many cases that in accident airbag fail to pop but still people survive and vice versa, just make sure you always wear seat belt and avoid rash driving until you get this fixed. 1 Link to comment Share on other sites More sharing options...
Massimo Posted August 5, 2014 Author Report Share Posted August 5, 2014 Well if light is one, then that means that SRS system is having some fault somewhere. However its seriousness will be known after getting the proper diagnostic with LR scanner. From safety point yes its serious, but from driving point it is not, and it doesn't affect other part of car. There are many cases that in accident airbag fail to pop but still people survive and vice versa, just make sure you always wear seat belt and avoid rash driving until you get this fixed. Thank you! Link to comment Share on other sites More sharing options...
girix Posted May 21, 2015 Report Share Posted May 21, 2015 It is probably a glitch in the system, but you need to take it to the dealer and check this issue as fast as you can. Air bags can be very helpful in cases of car accidents and you can't risk to drive your car with a faulty air bag. Link to comment Share on other sites More sharing options...
