rathod Posted May 23, 2011 Report Share Posted May 23, 2011 there is something leaking below my engine and i was worried sick what it could it be so i took the car and the dealer says that its a radiator leak and we will fix it do i fix it or change it i need votes and explanation if possible please Link to comment Share on other sites More sharing options...
daarei Posted May 24, 2011 Report Share Posted May 24, 2011 If its with dealer i am sure they will do the needful of fixing or changing as needed. Nobody can vote their choices without seeing it and properly diagnosing it. If radiator is leaked its usually better if you replace as very few people repair and dealer always replace. If its leaking from hose to and fro to engine then they will change those hoses and call it a repair work. Link to comment Share on other sites More sharing options...
jasan Posted April 21, 2012 Report Share Posted April 21, 2012 Were you able to ask where the leak was? I mean was it the actual radiator that has the leak or is it the hose? If the hose is the one with the problem, you might want to do it yourself to save money. If it has something to do with the radiator, you might want to have it replaced because sometimes the repairmen who do radiators can be sloppy and only a few of them does it. Link to comment Share on other sites More sharing options...
