guptaa Posted December 10, 2011 Report Share Posted December 10, 2011 I have to get a new horn or not i want a 2nd opinion as what part of the horn has to be changed. Is i the fuse or the horn itself The problem is when i press the horn i keeps on blowing even after i release the pressure and At times when i press the horn it dose not blow at all. Please advise. Link to comment Share on other sites More sharing options...
veers Posted December 11, 2011 Report Share Posted December 11, 2011 try changing the fuse which is a cheaper fix and if still dosent work then change the horn itself. Link to comment Share on other sites More sharing options...
guptaa Posted June 18, 2013 Author Report Share Posted June 18, 2013 after almost two years of changing the wiring i have same problem again...... Horn is a big problem Link to comment Share on other sites More sharing options...
rahuljones Posted June 25, 2013 Report Share Posted June 25, 2013 If you press the horn and if it stays ON it should probably be the sensor which is inside your steering wheel. Link to comment Share on other sites More sharing options...
guptaa Posted July 2, 2013 Author Report Share Posted July 2, 2013 changed wiring, fuse and sensors. still the same problem. Link to comment Share on other sites More sharing options...
