idris Posted November 13, 2013 Report Share Posted November 13, 2013 Hiya ... i have a 6 series convertible and the automatic convertible top wont close/secure completely. Has someone else come up with this kind of problem before? or can someone help me to look into the issue? What can it be the motor or the closing options? Is there an alternative way to close it till i can take it to the dealership guys? Link to comment Share on other sites More sharing options...
charl Posted November 25, 2013 Report Share Posted November 25, 2013 Isn't that kind of information normally found in the manual? no one can tell you what is causing the issue online but im sure that it is either the motor or the parts related to it. you might have to get some parts changed. Have you taken it to the mechanic yet? Link to comment Share on other sites More sharing options...
matt Posted December 24, 2013 Report Share Posted December 24, 2013 Hi idris, did you find a solution to this problem. I am having the same issue with my convertible and was wondering if you can tell me how you remedied the problem! Thanks a bunch. Link to comment Share on other sites More sharing options...
charl Posted December 25, 2013 Report Share Posted December 25, 2013 If you know your way around the car there is a simpler way to secure the convertible top but the problem is that its not a permanent solution. If there is a problem with your convertible top closing then you need to have it checked but if you just want to secure it completely you can look into doing it by yourself. Link to comment Share on other sites More sharing options...
idris Posted December 25, 2013 Author Report Share Posted December 25, 2013 hello guys, yes sorry for not posting an update. I had it fixed at the dealership. There was an issue with the top mechanism and they had to access the wires attached to the motor which were disconnected. Anyways the top works perfectly now. I would suggest you go directly to get it fixed. Doing it yourself might cause problems on your luxurious car Link to comment Share on other sites More sharing options...
