How to repair a horn?
  • 3 weeks later...
The horn completely stopped or the horn volume is really low?
If the volume is low, then you have to open the hood and check for the horn connector near the radiator and fix the connection problem. If the horn is not working completely, it means the fuse is gone. You need to fix the fuse.
  • 9 months later...
