Noisy Wheel Bearing
saifrr
  • 1 month later...
Awesome. Since the wheel bearing is too lose in your car, you need to tighten the hub nut on you wheel using the wrench. But do that after putting hand brake in your car. Then test drive your car to check the wheel bearing. Don't tighten it too much and the drive is too stiff.
