balajitr
Downsize wheels
My Edge Sport 2016 came with 265/40R21 tyres. While it does look nice, I would prefer not to feel every imperfection on the road. I don't make sharp turns at high speeds and so I don't need the better handling capability of the huge wheels. I chose the sport model over the titanium one for the EB engine and its straight line pickup.
I had a Murano earlier and its 235/65R18 tyres were so much more comfortable.
This URL tells me that the below tyres (and appropriate rims) are also compatible with this model.
235/60R18
245/60R18
245/55R19
245/50R20
The owner's manual confirms that 235/60R18 is indeed the 'winter' tyre size.
My 2 questions:
1. Has anyone downsized their tyres and found that the ride comfort is better?
2. Recommendations for good wheel and tyre shops as I can't find any this combination on any of the online sites?
Thanks to all in advance.
You are right. 21s are pretty bone jarring on anything less than a very smooth surface. You can go down to 245/60 18 without any issues because your tyre diameter will largely remain unaffected and your ride will be a lot more smoother too.
Until that time check if you are not over inflated too. And also this heat will increase your tyre pressure by quite a bit, making the tyre even stiffer.
Yes, I wondered about that; the difference is 3PSI after just 30 minutes of driving. I often adjust the pressure so that the cold tyre pressure is 2 PSI below the recommended one.
    • Zinc-Air batteries
      Zinc-Air batteries
    • Cats eyes to be renamed
    • Screenwash in engine oil
    • Cheap sand tyres!
      Cheap sand tyres!
    • Inline & Boxer engines differences - video
    • Family outing with BBQ - 18 August
    • Power Steering Oil
      Power Steering Oil
    • The green rock dawg spiderlike rock crawling thing
    • Doing it WRONG!!! Off-road Mistakes and Learning
    • Desert Exploration Night Drive (UAQ) - 3 August
    • Around the UAE in one day - 15K members drive
    • Carnity Has 15K Members !! Hurray !!
    • Toyota mega cruiser
      Toyota mega cruiser
