Best way to prevent a flat tire?
Aside from making sure that your tires have the correct pressure, you can also do a habit of checking the tire threads. If the tire threads are already half way through, that you might want to replace it only if you really want to avoid getting to situations where you'll get a flat.
  • 1 month later...
  • 1 month later...
  • 3 weeks later...
