Trip report- It's always a challenge heading to the deflation point with the family and packing up the car with equipment and food. This Friday was no different. As a result I got a bit delayed reaching the meeting point. I received a call from @Gaurav bhai that he has 8 cars and a few more people running late, so not to miss a good spot he will head in with the 8 cars and block a space for us. As I reached I saw @Asif Hussain drive in with his white Pathy for the first time, @Praveenmp was next in with @Shamil to be the last to join. As we deflated we were joined by @Gaurav bhai who lead us to the spot.
@Gaurav bhai strategy had worked out wonders as we got a great spot and soon we were trying to arrange our cars to block the idiots throwing sand in that area as well as make space for us to lay our spread. The conditions were not the best though as the sands kept shifting which was later evident by the amount of sand gathered on the mats.
As everyone started to put their offerings on the mat it was full of goodies which made us watch every second go by to break our fast and sink our teeth into the goodies. The variety was amazing and although we did not discuss over the forum what each one of us will be bringing but there was no duplication. As it was time for Azaan and we broke pur fast, one great treat after another awaited to wet our appetite for more.
We took a break from eating to offer our Maghrib prayers behind Imam @Asif Hussain. We slowly continued to munch and drink to fill ourselves. @Shamil at this point discussed his bucket list which included a climb on the Iftaar bowl. I suggested I have a go first before he tries to give him an idea which he agreed to. This was later approved with a smile from @Gaurav bhai who was walking our way to suggest the same.
For the initial drive to the base of the bowl I just was trying to get a feel for the Xterra. With the way clearing out I made a dash for the approach and soon we were riding the ridge on the left side. The Xterra with a never say die attitude kept climbing the dune like it would treat a highway. Soon we had reached the tip and I made our way back to the bottom. @Shamil was feeling confident that he knew what was to be done. However being fairly new to off roading his timing to accelerate and approach angle were a bit off due to which he had a few failed attempts. I tried to show him once again what he has to do and once again it climbed all the way without breaking a sweat. Coming down at an angle where I could build the kind of angle and momentum to approach the right side. Successfully but slightly more difficulty the Xterra made it to the top from the right side as well.
At this point @Shamil knew he had it and tried once again, thinking about it now I feel the lack of light might be a reason for him not to get his timing and angle right. One last time up from the left side and we headed back to the convoy. I heard a slight wobble and stopped to notice the rear right tire deflated. It was not a pop out so we tried refilling the air but to no avail. By this time @Gaurav bhai had made it to the scene, we decided to Jack it up as the load on the tire might be creating a gap for the air to escape. Next it was the valve to be removed but after several attempts we decided to remove the tire to try and remove any sand sticking between the rim and the tire sidewall. Upon closer inspection we discovered that the rubber inside the rim had torn away not allowing the air to stay in the tire. At tis point we had to use the spare and due to its condition we had no choice but to exit him. @Emmanuel also announced on the radio that @srini62 was facing a similar issue and by the time we headed back that situation was also under control.
Some of the cars had decided to head back led by @Emmanuel. As @Gaurav, @Asif Hussain, @yogic72@srini62 and myself decided to have a quick drive. It was a challenging drive with some refusals and stucks, but we kept marching on.
As soon as we made our way out we headed to the pump. Here we inflated our tires and after some heartfelt hugs headed back home. This is one of the best Grand Iftaar we had in a long time all thanks to the people who made it for the drive.
  • Like (+1) 6
