vishal Posted July 7, 2011 Report Share Posted July 7, 2011 after getting check engine light i got it diagnosed and found out the the cylinders 4, 5 and 6 are misfiring and was asked to get the following things changed ignition coils spark plugs, Coolant Temp sensor and repaired crankcase vacuum hose. the car ran fine for 5 days without the light and i was under the impression that it fixed and again the light came up so i changed the Evap purge Valve and then replaced one Catalytic converter (Bank 1) but the light still remains and now they want to change the Engine Control Module, but they dont guarantee that it will solve the problem. All this cost me 10,000K and i am still pointing arrows in the dark i feel cheated and want some advise please Link to comment Share on other sites More sharing options...
audiawd Posted July 8, 2011 Report Share Posted July 8, 2011 check engine is a big ocean of possibility and i don't think you are getting cheated get he ECM changed and see it is repairs it but one thing is for sure that ECM faultily is one of the causes of misfiring all the best Link to comment Share on other sites More sharing options...
ansaari Posted July 12, 2011 Report Share Posted July 12, 2011 Also doubt on air seals, especially manifolds one and butterfly ones. Good luck, mate. Link to comment Share on other sites More sharing options...
iroc Posted July 16, 2011 Report Share Posted July 16, 2011 Can you be more specific on the model and engine code. Since one bank of the engine is misfiring it could also be faulty valve timing. Link to comment Share on other sites More sharing options...
