Gregory Posted June 13, 2021 Report Share Posted June 13, 2021 I have the same (camel) twin compressor as @Tareck I bought it at DM for around AED 240 if I remember correctly. Inflates my tires from 13PSI to 34PSI in around a minute - but it does get very hot, especially if I'm on a day drive and the compressor is in the sun. As I paid only AED 240, I won't feel very sad when it stops one day.. melts or blows up - and then would like to upgrade to something like @Anish S has. 4 1 2 Link to comment Share on other sites More sharing options...
Frederic Posted June 13, 2021 Report Share Posted June 13, 2021 1 hour ago, Gregory said: I have the same (camel) twin compressor as @Tareck I bought it at DM for around AED 240 if I remember correctly. Inflates my tires from 13PSI to 34PSI in around a minute - but it does get very hot, especially if I'm on a day drive and the compressor is in the sun. As I paid only AED 240, I won't feel very sad when it stops one day.. melts or blows up - and then would like to upgrade to something like @Anish S has. If your hoses and cable are long enough, try to put the compressor on your seat. There will be less risk of dust getting inside and it will run cooler as well. 3 2 "Go as far as you can see; once you get there, you'll be able to see further." Link to comment Share on other sites More sharing options...
topgear Posted June 13, 2021 Report Share Posted June 13, 2021 I have used a Bushranger Max Air III and it was good. The compressor is still working fine. Now I am using Mean Mother that came with a remote control and so far so good. 4 1 Link to comment Share on other sites More sharing options...
Russ Posted June 13, 2021 Report Share Posted June 13, 2021 (edited) Hi @Super Safari Girl, after starting out with a TJM single compressor I quickly realised that it wasn’t up to the job - took too long and cut out in summer temperatures before I had reached ideal pressure…I decided to install an on-board ARB twin compressor and together with a 4-in-1 hose system it’s a complete game changer! A process that previously took the best part of 30 minutes is now done in less than 10…not cheap but definitely worth it.. Edited June 13, 2021 by Russ 5 1 Link to comment Share on other sites More sharing options...
Super Safari Girl Posted June 13, 2021 Author Report Share Posted June 13, 2021 @Russ thanks for the input. ARB seems like the consensus. I’d rather invest in something once rather than get the wrong things and waste money. @topgear I looked up Mean Mother (love the name 🤣) because a few of you mentioned it, but it seems hard to find in Dubai. 2 Link to comment Share on other sites More sharing options...
topgear Posted June 14, 2021 Report Share Posted June 14, 2021 @Super Safari Girl just google "Mean Mother Air Compressor - High Output 160LPM dubai" and you may get some leads 1 1 Link to comment Share on other sites More sharing options...
Anoop Nair Posted June 14, 2021 Report Share Posted June 14, 2021 41 minutes ago, topgear said: @Super Safari Girl just google "Mean Mother Air Compressor - High Output 160LPM dubai" and you may get some leads There is a shop in AL Qusais it is readily available, an internet search as mentioned will give you the address and details. 1 1 Link to comment Share on other sites More sharing options...
Lawrence_Chehimi Posted June 14, 2021 Report Share Posted June 14, 2021 On 6/12/2021 at 10:37 PM, Thomas Varghese said: @Shaaz Sha has bought a new 4 cylinder compressor which can inflate all 4 tires under a minute or two. It has double outlets for inflating and its sort of semi automatic. I don't know the brand name but as per @Frederic it has some great reviews in the internet. Cost is around 600 AED. Link to comment Share on other sites More sharing options...
