Afternoon Fewbie Desert Drive - Lesaily Run (Lisaili to Qudra) - Dubai - 3 Jun 2023
Looper
DRIVE PLAN
It will start on a crisp afternoon. We will encounter some freshly baked afternoon desert. Our aim will be to cross the midsized dunes to reach the long-range dunes to practice some Criss-crossing and reach Qudra roundabout.
We request every member that joins this drive to go through the information below and strictly follow these guidelines, etiquette and responsibilities.
DRIVE DETAILS
Level:  Fewbie and above
When:  3 June 2023, Saturday
Meeting time:  3:00 PM - Sharp (Without any exceptions)
Meeting Point: https://goo.gl/maps/UDzJ7FKT2Aq5HcyFA
Approximate finish time: 7:00 PM
What to bring along: Loads of water, snacks (for yourself), smiles, enthusiasm, and willingness to learn.
Mandatory off-road gears: Tire deflator, tire pressure gauge, compressor, walkie-talkie radio, off-road flag, shovel, first-aid kit and fire extinguisher.
LIMITED SPOTS AVAILABLE
  • This drive is limited to 10 cars only. RSVP will close on FRIDAY - 12 PM
PLEASE RSVP ON BELOW CALENDAR
  • Gaurav changed the title to Afternoon Fewbie Desert Drive - Lesaily Run (Lisaili to Qudra) - Dubai - 3 Jun 2023
On 5/29/2023 at 11:00 AM, Looper said:
DRIVE PLAN
DRIVE DETAILS
Hi guys, happy to see you in 1 hours time!
5 minutes ago, Pavel Pashkovskiy said:
Perfect drive! Thanks to everyone. @Looper @DP1011 you are the best!
Thanks @Pavel Pashkovskiy for the Coffee /snacks As Always!!! It makes a difference to drive and makes it more enjoyable with coffee break:)
@Looper What a fantastic FB drive, the blend of technical and long range was so well balanced and Fantastic display of skills by the entire convoy ! @george charbel U did brilliant as SL, being your first one!! And thanks @Gok Krish for sweeping us and those couple of quick tugs made us kept moving swiftly.
See you all soon in sands again ;)
We started as early we could, but it was quite hot anyways, hovering about 42 degrees. I am was quite trilled by the performance entire convoy including the tricky technical area. It was great to see the convoy perform exceedingly well.
@Pavel Pashkovskiy thank you once again. The drives with you are one of a kind with the mid drive refreshment breaks. It is unforgettable.
@Mohit Gurnani I see you do better and better every time I have driven with you. great to see you once again.
@Frans M wonderful to see you once again. as many have pointed out, we all love your ride.
@Cristian you did exceedingly well. great to see you.
@premindra rajaram once again it was wonderful to have you in another drive.
@Gok Krish thank you very much for being at the back and taking care of the refusals. It was a pleasure having you in the drive.
@george charbel You did fantastic in your new role as second lead. I have driven many times with you and that gave me the confidence of having you there and you were spot on.
@Anoop Nair Thank you for joining the drive. hope the jeep is all good now.
@Nadeem Ansari you did very well on this drive. I see you becoming more and more polished every week.
@DP1011 finally thank you very much to heed the call and join back to back 2nd drive of the day to support this drive.
I could hardly take any pics but still managed a few. I have added some pics in the gallery,
See you all in the next instalment of Looper's loops.
  • Thanks (+1) 3
