rroker Posted April 25 Author Report Share Posted April 25 So I visited Al Habtoor today, explained the situation to them. They did a complete inspection (test drive, OBD, etc.) and suggested that the differential is the root cause. They also ruled out wheel bearings as a cause and told me that those would make a consistent noise. Suggested repairs by them includes replacement of solenoid valve, free wheel switch and hoses. If that does not fix the problem then the actuator and all 4x4 switches need replacement. The leak in differential was a false alarm, it was some leftover WD40 from the timing belt replacement job 😅. My personal experience with Al Habtoor was a good one. They were professional and quite helpful. Have to give credit where it's due. My Pajero is still under Al Futtaim warranty (Automall purchase), so I will be visiting them to get the fixes done. I have already visited Al Futtaim Auto Care Centre twice in the past for this particular issue, both times they said "we cannot fix what we cannot observe". So I am under immense pressure of recreating the noise during test drive when I will visit them again. If the noise does not occur during test drive then I will insist on the video being proof of the problem (already tried in the past) and of course diagnosis from the official Mitsubishi Service Center Al Habtoor. @Marek @Frederic I found a post on an off-roading forum about this exact issue where people have (over) analysed this issue. I am pasting the technical explanation from that post to shed some more light on this issue: Quote "Front axle mechanism trying to engage due to a faulty sensor, solenoid, vacuum line or actuator causes the gears to clash. As the default state for the front axle is engaged, any fault would cause it to try to engage. If the transfer lever is in 2H the front drive shaft would not be turning causing the gear clash in the front axle and as you stop the click you hear is the gears engaging." BTW while driving today I was able to turn off the noise again by switching from 2H to 4H. I will do some more research as well as tinkering and hopefully get the car to make the noise on command. That would make my life much easier when trying to explain this fault at the service centre. Would appreciate any tips to recreate this sound when I want for demonstration purposes. I will keep you guys updated. Thank you! 1 1 Link to comment Share on other sites More sharing options...
rroker Posted April 25 Author Report Share Posted April 25 (edited) Found an old Carnity post about a similar problem, suggested solution was replacement of solenoid valves: Edited April 25 by rroker 1 Link to comment Share on other sites More sharing options...
Frederic Posted April 26 Report Share Posted April 26 13 hours ago, rroker said: Found an old Carnity post about a similar problem, suggested solution was replacement of solenoid valves: The bliss and value of Carnity archives ! 1 1 "Go as far as you can see; once you get there, you'll be able to see further." Link to comment Share on other sites More sharing options...
