UAE'S MOST ENGAGING CAR SITE
Sign in to follow this
arnldz_2005
Windshield Water & Coolant
Hi am arnldz,.
Got myself used 2005 Focus Hatchback, just seeking an advise from the group of what i am troubled indeed,.(Take note: Engine is cool & in good running condition),Only for:
Windshield Reservoir,have to filled it out from 50km run for almost a liter of water even am not using the windshield washer,
The coolant consumption almost 4 gallons from average 6k Km run,.
Please advise to both with unseen leakage,..Thanks & More Power,...
There is a water leak for sure for your windshield washer, otherwise washer water isnt used anywhere. How to find out is the question. Remove the washer bottle by lifting it upwards (usually) go figure out in ur focus. Once bottle is out make it empty and dry and then fill water (outside the car) and test for any minute leak from below. If bottle is clean, then next and only thing to doubt is the washer hose, which tend to get crack as its near the engine heat and start leaking a bit. If thats the case then change those water pipes, its cheap anyways.
About coolant, it should never be consumed firstly. Check visually under the car for green sticky deposit to see from where coolant is seeping. These minute leaks are difficult to trace as you cant find the spot on floor but it deplets when you drive. It has too many things to doubt that first look under the car can get you good starting point. If you cant figure out, drive to enoc pump and mechanic over there can quickly pin point the leaking spot. Just for clue: check the black water hoses joints, check the engine base, check radiator all around, check the coolant expansion bottle and its hoses for leak.
hi guys,.coolant lekage reveal on Heater Panel drain pipe,.yes it's scary as mr colonel expectation & yet expensive too,.but am planning to bybass the heater for budget wise though were here in GCC for self explanatory,.would it be possibel?/ & is there any body gone this bypass whom could guide us which garage workshop did it well in reasonable price..regards,...
