rubbing noise when coasting
Check the underbody if something is getting against the driveshaft or other moving part. May some plastic or heatshield hanging around and getting rubbed.
Discovery has notorious U joint on drive shaft. If in doubt disconnect front U joint and drive and see if noise disaapear then that means its the cross (u joint) you have to change.
