Engine raising Noise
What type of noise is that?
If its engine fan (aka radiator fan) then its normal in peak summer while idle engine tends to slide to bit overheated zone and thats where engine fan works at full rpm than half (while car at normal temp), and when you accelerate from zero you will hear the fan kicking at high rpm too making lot of noise, which disappear after few seconds of movement as radiator get cool air and temp slide back to normal operating zone.
  • 1 year later...
Thanks for the explanation wasimay. But, is it possible that the problem is located somewhere else and the engine just creates the noise? I mean if the problem is in the coolant or in some other car part it will also affect the work of the engine.
