starter or fuel system
Its fuel system issue, and that too fuel pump delivery is getting delay when tank is full.
I had same problem but exactly opposite one. Less than half tank fuel it take 5 -6 cranks to start and also hesitate while driving with full throttle. On checking it seems fuel pump O ring was bad and loosing the pressure. Mechanic repaired the fuel pump and it was fine.
