when do i change the tier
trejor
it really depends on the usage and maintenance of the tiers if you are not using the car too often or if u rotate them time to time, check the pressure then they last longer
the best is check its tread with a tire tread depth gauge and if the measurement is minimum of 1.6 mm then anything less the the tiers has to be changed.
