when do i change the engine oil.
  • 2 months later...
  • 3 months later...
in normal circumstances the engine oil is changed every 48,000 km but its advisable to check with a good workshop.
Are you sure you mean 48,000 km . Because its just making the car junk. Well the other guy is right you should change it after 5000 km. Because when the oil runs more it loss the power so try to change it after 4500 or 5000 km.
  • 2 weeks later...
  • 2 months later...
  • 4 weeks later...
  • 2 years later...
Do you use your car ona  daily basis? In that case I suggest changing it evry 9 months. Of course, you should look at the mileage too. It is not adviseable to drive your car with the same oil after 10.000 miles.
