vincent76 Posted October 19, 2012 Report Share Posted October 19, 2012 Hi Guys, I have a question in relation to manual shift mode. Based on my understanding, once the shifter/lever is moved from automatic to manual mode slot (idle position) you will get M1 (as shown on your dash). However, my Pathfinder get M4 at idle position. Is this the way it should be? Your response will be highly appreciated. Thank you Link to comment Share on other sites More sharing options...
newtoni Posted October 19, 2012 Report Share Posted October 19, 2012 Can you please elaborate more, i didn't understood your question fully, secondly which year pathfinder it is? Link to comment Share on other sites More sharing options...
vincent76 Posted October 20, 2012 Author Report Share Posted October 20, 2012 Thanks for your quick response. To start with, the model of the car is 2008 Pathfinder LE. On idle position, once I moved the shifter from D position to Manual mode the indicator shows 4 (meaning in 4th gear already) which I believed the indicator should show 1 (first gear). I'm just curios whether this is a factory setting or not and if it will cause me a problem or not. When the lever/shifter is moved to D position (automatic mode) the driving condition is normal. Hope this clarifies my question. Thank you Link to comment Share on other sites More sharing options...
newtoni Posted October 20, 2012 Report Share Posted October 20, 2012 It seems like a factory glitch to me to show on dash 4 in place of 1 (may be they meant D4 only), as far as you can manually shift fine from 1 to 4, don't bother much. But its a good point to report to dealer so that they can report this to Nissan Japan. Link to comment Share on other sites More sharing options...
vincent76 Posted October 21, 2012 Author Report Share Posted October 21, 2012 Thanks very comforting. I will report this issue when i visit the dealer. Link to comment Share on other sites More sharing options...
