particle filter additive level too low
ok now since u have a diesel; diesels emit pollution containing large particles of carbon...a way to reduce the emission is to fit in a particle filter, just like a cat converter. the message u got is because that filter is getting a bit blocked......what i can suggest is to go for a long drive (an hour or so) at a speed of around 60 - 80 kmh to allow the particles to be burned off. when u stop again, disconnect the battery IMMEDIATELY after switching the car off...leave it off for 20 minutes. when 20 minutes is up reconnect and go for a drive. if the fault still comes up u will have to have the filter replaced at the dealer
ADAPT Performance - Power Unleashed
SOFTWARE TUNING & PERFORMANCE PARTS
www.adaptperformance.com
