timjim Posted August 30, 2011 Report Share Posted August 30, 2011 I have got the Front Driver Side axel shaft and seal changed but the fluid is still leaking. What should i do now. I cant drive because of this problem, my car is 2003 Camry. Link to comment Share on other sites More sharing options...
rashidr Posted August 31, 2011 Report Share Posted August 31, 2011 As you said the the fluid is leaking you will need a seal driver, which expands the garter spring in the seal.get the correct sise and remove the seal and replace it. Link to comment Share on other sites More sharing options...
