nizamNIjju
Ford Edge Overheats when AC turns on only
My Ford Edge 2009 model overheats when AC turns on. checked fan, its turns ON  only for a few minutes. There is lots of rust in radiator. Kindly give me suggestions.
If you have a lot of rust in the radiator, first thing you need to flush all the old water and out new water drive it few hours. Flush all the water again and put coolant.
Thanks or your quick reply. So overheating of my car might be due to radiator rust???
Could very well be rust in the radiator causing it. Get the garage to check the water pump is working properly when you flush it all out. Give the fins of the condenser and radiator a good wash with a low pressure hose too.
Thanks lot Mr Barry for your support.
maybe the fans are turning but not at the required speed...and in rare cases the engine itself might be weak that's why when you put load of compressor or push it abit hard and it starts to heat up along with what @sertac and @Barry mentioned
Thanks mate. I went for checkup last day. They found that condenser is not working. Is that true? can u suggest some good workshop for ford with affordable labour charges please.
Issue fixed. It was cooling fan relay module. fixed from Sharjah industrial area.
Hi Nizam
Pls guide me how much did u spend for the same.my car has the same issue
I also need help to change the tires as it's due for renewal
I spent jus 600 including fitting charge. Shop is located in industrial area sharjah near to bmw. Pls do not drive if it is over heating. U will find tires for 300 to 700. U can contact me (Please PM mobile numbers, Do not share openly on forums. Thanks) for route guidance. This is well known issues in ford cars.
Edited by Jeh
Mobile Number. Privacy Issue
  • Similar Content
    • By VishalJC
      Hi everyone!!
      This is Vishal here, been in UAE for past 3 years, I don’t have ride of my own… but that didn’t kept me following my ever loving topic “cars”☺️..
      Most of the time my search results always end on one of your forum discussions!! And yeah it is helpful and practical.
      Yearly once or two I rent a 4x4 and go for camping with my friends (last one was shuweihat island ).
      Looking forward to meetup with you guys!!
    • By Barry
      Somehow lost VW connectivity so decided to run an update. Some new manufacturers I haven’t even heard of.
    • By Barry
      Pick a car, pick an engine.
      What is your dream engine swap and why?
    • By Barry
      British tourist hits every speed camera on Sheikh Zayed Road  in a rented Lamborghini Huracan and racks up 175,000 dhs in fines.
      https://www.bbc.com/news/world-middle-east-45085991?ns_source=twitter&ns_mchannel=social&ns_campaign=bbcnews&ocid=socialflow_twitter
