Boney John
Bigger rims for pajero
Hi everyone,
I would like to ask all your valuable experience regarding rim size. I am new to this group , have recently bought a 2012 3.5L pajero (4 door)with 78k km. I have stock 17" rims on it ,thinking of changing to a stylish rim, maybe 18" or 19. I dont plan to do much off road driving ,  so it would just be for a cosmetic change . I just did a sample try in a shop near sharjah * (pic below but that was 20"). I have no idea about Tyre sizes or alignment and stuff like that. Kindly give some advice on this . Thanks :)
I haven't understood your question clearly, what exact advise you are looking for.....!
17 inch itself is borderline acceptable for offroading if you bump to 18 or 19 with a low profile or medium profile tire its a COMPLETE NO for offroading. I really doubt you can add normal profile tire on 18 or 19 without lifting 2-3 inch or else it will result in rubbing the wheel arch on turning.
@Gaurav he has mentioned that he is looking for a bigger rim for cosmetic purpose only as he rarely drives off-road.
I have seen stock Pajero with bigger than 18 inch rims, but I guess you need to get a good rim and not just from the Iranian shops as they might cause vibration at high speeds. This is only a hunch, am not sure though.
As I said , i wont be going offroad at all . I like big rims. So i was thinking if ever i put an 18” or 19” would that be an issue in handling / fuel economy/ or any other disadvantages .
Now its clear, what's your current tire size like 265/55/R17.....?
And what's the stock tire size mentioned in owner manual?
Stock size for pajero is
16” Rim-265/70/16
17” Rim-265/65/17
18” Rim-265/60/18 (For 3.8 Only)
16” Rim-265/70/16 = 30.6 Inch
17” Rim-265/65/17 = 30.6 Inch
18” Rim-265/60/18 = 30.5 Inch
19” Rim-270/55/19 = 30.7 Inch
20” Rim-265/50/20 = 30.4 Inch
You can calculate your stock tire height first and then upgrade to any other wheel size + downgrade the profile of tire to result in overall similar height, to avoid any rubbing issues.
Here's how to calculate tire height
Example: 16” Rim-265/70/16 = 30.6 Inch
265 x 70% = 185.5 mm (One side profile height of tire)
185.5 x 2 = 371 mm (up and down profile height of tire)
371 mm = 37.1 cm = 14.6 Inch (Total profile height of tire in Inches)
14.6 Inch + 16 Inch Wheel = 30.6 Inch total tire height
  • Like 5
Mines 265/65/R17 . Anyways will check out with some shops. I heard that bigger size rims wil reduce fuel consumption n ride quality .
The bigger the rims get...the thinner the tire wall gets
why do you want to experience each and every pot and hole on the road...
Bigger size rims = more expensive tyres.
Bigger size rims = more offset in actual speed shown on speedometer.
Bigger size rims = not ideal if you or your significant other likes to park against the curbs.
Bigger size rims = will probably slightly increase fuel consumption, but not sure of that.
Bigger size rims = less tyre height = will drive "harder" on the road, less comfort.
Bigger size rims = will make you stand out more of the "regular" Pajero driving crowd :)
  • Thanks 1
  • Haha 1
