Javier M Posted May 20, 2019 Report Share Posted May 20, 2019 What do you guys think? - I may put this in my list of upgrades. 3 Link to comment Share on other sites More sharing options...
Gaurav Posted May 20, 2019 Report Share Posted May 20, 2019 As much as both videos try its best to make it very convincing to have, but my question to more technically capable members if these fumes and contaminants left in the system, won't they get collected in engine oil filter.....? If not, then why manufacturers are designing cars without a catch can? 3 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
Barry Posted May 20, 2019 Report Share Posted May 20, 2019 4 hours ago, Gaurav said: As much as both videos try its best to make it very convincing to have, but my question to more technically capable members if these fumes and contaminants left in the system, won't they get collected in engine oil filter.....? If not, then why manufacturers are designing cars without a catch can? Simple answer, Emissions regulations. That’s why catch cans don’t come as standard. With a catch can, you’re venting gases directly to atmosphere whereas with the standard PCV system, the gases are pumped back into the engine and burnt. The oil filter doesn’t take all the contaminates out of the oil. If you’ve ever taken a sump off an engine and seen all the crap in the bottom, you’ll understand. 3 1 2 Link to comment Share on other sites More sharing options...
shadow79 Posted May 20, 2019 Report Share Posted May 20, 2019 For old oil we can put new oil while the drain is open so as soon as new oil starts to come out we can close the drain bolt. But it's new oil which could add a liter more in price of changing oil price...and yet the heavier things still are there in the sump itself unless you open the sump and clean it manually.... 1 1 Link to comment Share on other sites More sharing options...
