How do I stop my roof rack from whistling?
Chirag S.
On 6/24/2019 at 11:20 AM, Srikumar said:
@Chirag S. have a look at the below video. You will need do something similar for your roof rack to reduce the noise. The other option which is easier is to get a custom made cover, and just close it.
Never expect this sound from the LED light bar
Not sure if this will overheat the LED bar, the whole point of that shape is to serve as heatsink and dissipate the heat that the LEDs generate.
  • Confused (0) 1
The noise will come from anything that alters the shape of the vehicle. Including but not limited to roof racks and LED bars. I installed LED bars in my jeep and also hear the whistling. But I already expected this.
Edited by Javier M
Very true!! These noise are expected!!
You can sacrifice for the stunning look🎊
