Mystery coolant leak in Pajero
It shouldn't be a mystery leak if all the three times the leak was indeed found...
Have seen this happen in many old as well as new cars it's always the next weak spot which gives way then sooner or later it has mercy on you and leaves you alone for sometime...
People who mix different kind of coolants f**k up real bad yet time and again they do it or someone does it for them
Even people who use bottled water or line water also have it coming at them as those minerals in the water are gonna make things go cucu sooner or later
The only thing which makes sense theoretically is always using same brand and type of coolant and just incase you can't find it then used air conditioning drain water as when that evaporates it shouldn't leave minerals behind....
