Janarthan Posted June 8, 2020 Share Posted June 8, 2020 Hello @Frederic @Gaurav This is my second ride with the group and but this time i am doing it with my own car which is xterra but it doesn't have option to turn of the traction. Mechanic said we need to install a kill switch. But my question is do i need to do that for newbie drives or can it wait. Thanks, Jana 4 Link to comment Share on other sites More sharing options...
Frederic Posted June 8, 2020 Share Posted June 8, 2020 1 hour ago, Janarthan said: Hello @Frederic @Gaurav This is my second ride with the group and but this time i am doing it with my own car which is xterra but it doesn't have option to turn of the traction. Mechanic said we need to install a kill switch. But my question is do i need to do that for newbie drives or can it wait. Thanks, Jana Hi @Janarthan i am not an expert in Xterra. Probably @Shamil @Chaitanya D @Kalahari @Desert Dweller @Emmanuel or somebody else from the Xterra Crew can assist in this ? 5 1 "Go as far as you can see; once you get there, you'll be able to see further." Link to comment Share on other sites More sharing options...
Rahimdad Posted June 8, 2020 Share Posted June 8, 2020 Hey @Frederic, you missed out on @Desert Dweller. 4 Link to comment Share on other sites More sharing options...
Emmanuel Posted June 8, 2020 Share Posted June 8, 2020 First can you check if you have this button or not ? it depends on which year and trim you own. Mine is 2012 X and I have this button. 3 1 Link to comment Share on other sites More sharing options...
Janarthan Posted June 8, 2020 Author Share Posted June 8, 2020 19 minutes ago, Emmanuel said: First can you check if you have this button or not ? it depends on which year and trim you own. Mine is 2012 X and I have this button. Hi @Emmanuel, mine 2009/S and i dont have this button. 4 Link to comment Share on other sites More sharing options...
dune jockey Posted June 8, 2020 Share Posted June 8, 2020 ABS kill requires the fuse to be removed from the fuse box in xterra (as per the map) which dont have ABS switch on dash, but it tends to light up some warning signs on dash. Best is to install a ABS kill switch which many garages do (about 50 to 100AED )considering that you will be driving it off road frequently. 4 4 Link to comment Share on other sites More sharing options...
Asif Hussain Posted June 8, 2020 Share Posted June 8, 2020 2 hours ago, Janarthan said: Hello @Frederic @Gaurav This is my second ride with the group and but this time i am doing it with my own car which is xterra but it doesn't have option to turn of the traction. Mechanic said we need to install a kill switch. But my question is do i need to do that for newbie drives or can it wait. Thanks, Jana You need to install ABS kill switch which will disable all your stability controls. For newbie drive it is not very important, but get it installed as soon as possible. ABS is not tuned well for off-roading in xterra it can occasionally kick in during steep slopes and keep releasing the tires making your xterra go down without break or control. You must kill the ABS if you are going for serious drives. There are two ways to deactivate ABS 1) With ABS kill switch, which will cost you 150 to 200dhs and you can control from your dashboard easily. On and Off without any hassle. 2) With Fuse Modification, (which I had did) Bought a 3 way fuse from scrap which costed me 10dhs that's it. Then remove the connection from inside the last 30amp compartment (as shown in the picture below) YOU ARE DONE......... Just replace the fuse before off-roading with original one while car is turned off and key is removed. Then start the car and you see ABS light and all other stability control lights are turned on in your dash, and you are ready for dune bashing 😀 After the drive just replace it with the original one with the car turned off and key is removed. Light will be still on but don't panic just drive for a minute and it will go off. 5 4 Link to comment Share on other sites More sharing options...
Janarthan Posted June 8, 2020 Author Share Posted June 8, 2020 59 minutes ago, Asif Hussain said: You need to install ABS kill switch which will disable all your stability controls. For newbie drive it is not very important, but get it installed as soon as possible. ABS is not tuned well for off-roading in xterra it can occasionally kick in during steep slopes and keep releasing the tires making your xterra go down without break or control. You must kill the ABS if you are going for serious drives. There are two ways to deactivate ABS 1) With ABS kill switch, which will cost you 150 to 200dhs and you can control from your dashboard easily. On and Off without any hassle. 2) With Fuse Modification, (which I had did) Bought a 3 way fuse from scrap which costed me 10dhs that's it. Then remove the connection from inside the last 30amp compartment (as shown in the picture below) YOU ARE DONE......... Just replace the fuse before off-roading with original one while car is turned off and key is removed. Then start the car and you see ABS light and all other stability control lights are turned on in your dash, and you are ready for dune bashing 😀 After the drive just replace it with the original one with the car turned off and key is removed. Light will be still on but don't panic just drive for a minute and it will go off. Thank you @Chaitanya D @Emmanuel, @Asif Hussain the option you have mentioned is fantastic but I decided to go with kill switch as I am completely new for off roading and also in understanding cars. Will post the kill switch pictures shortly , it’s getting installed as we speak. 4 3 Link to comment Share on other sites More sharing options...
Shamil Posted June 8, 2020 Share Posted June 8, 2020 5 hours ago, Janarthan said: Hello @Frederic @Gaurav This is my second ride with the group and but this time i am doing it with my own car which is xterra but it doesn't have option to turn of the traction. Mechanic said we need to install a kill switch. But my question is do i need to do that for newbie drives or can it wait. Thanks, Jana HI @Janarthan. If you decide to go via the kill switch route, then this diagram could be helpful. 5 3 Link to comment Share on other sites More sharing options...
Desert Dweller Posted June 10, 2020 Share Posted June 10, 2020 On 6/8/2020 at 5:57 PM, Asif Hussain said: You need to install ABS kill switch which will disable all your stability controls. For newbie drive it is not very important, but get it installed as soon as possible. ABS is not tuned well for off-roading in xterra it can occasionally kick in during steep slopes and keep releasing the tires making your xterra go down without break or control. You must kill the ABS if you are going for serious drives I only have the Traction control switch button, and I do notice now that I'm doing more serious drives that the car needs ABS kill switch too. But I did fine without it in Newbie drives. 6 Link to comment Share on other sites More sharing options...
