Popular Post Gaurav Posted September 1, 2020 Popular Post Report Share Posted September 1, 2020 I just been to service center today for an oil change and spotted another Pajero on the lift. I couldn't resist to take a pic of how badly tow point can get rusted and imagine if this Pajero comes to offroad and needs a tug. And when this breaks and cause all the damage, it will be blamed on Mitsubishi stock points. So everyone who are offroading weekly, please check your tow points regularly, at least once every 3 months. If any tow point is loose or shaking get it fixed. It will surely break. If its rusted like this, take a wire brush and scrub all to see if it's superficial or deeper. Once clean if it superficial, spray paint with couple of layers to prevent rusting again. If its rusted deep, better get it changed with new rated tow point and rated bolts. 4 3 3 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
Barry Posted September 1, 2020 Report Share Posted September 1, 2020 A lot of times the rust starts from the inside and works its way outward. If the hook is mounted to tube/box section, it may be worthwhile to drill a couple of holes in it and spray the inside with waxoyl or similar. 3 1 1 Link to comment Share on other sites More sharing options...
M.Seidam Posted September 1, 2020 Report Share Posted September 1, 2020 3 hours ago, Gaurav said: I just been to service center today for an oil change and spotted another Pajero on the lift. I couldn't resist to take a pic of how badly tow point can get rusted and imagine if this Pajero comes to offroad and needs a tug. And when this breaks and cause all the damage, it will be blamed on Mitsubishi stock points. So everyone who are offroading weekly, please check your tow points regularly, at least once every 3 months. If any tow point is loose or shaking get it fixed. It will surely break. If its rusted like this, take a wire brush and scrub all to see if it's superficial or deeper. Once clean if it superficial, spray paint with couple of layers to prevent rusting again. If its rusted deep, better get it changed with new rated tow point and rated bolts. Thank you @Gaurav indeed 👍 the picture talks it all and it’s scary to imagine towing a vehicle “floating on a thread of rust “ emphasis on regular check regarding this matter is critically important . 58 minutes ago, Barry said: A lot of times the rust starts from the inside and works its way outward. If the hook is mounted to tube/box section, it may be worthwhile to drill a couple of holes in it and spray the inside with waxoyl or similar. Yes @Barry the unnoticed unappreciable hidden deeper rust is the problem and in @Gaurav pictures it looks the rust long time has started ! 3 Link to comment Share on other sites More sharing options...
Chaitanya D Posted September 9, 2020 Report Share Posted September 9, 2020 Sharing my experience with tow or recovery points for xterra on the front. - very cumbersome to fabricate. - design needs to be prefect with use of atleast 10mm steel I had mine done few months back, all was done with 10mm except the base plate which attaches to chassis which was slightly thinner as shown in pic below The one on the left got bent ( top one in the pic below)while tugging a few times from the front, as shown It was a struggle to get this out as the base plate had to be cut after removing the skid plate and radiator bracket and replace a new one which was done with 10mm steel all around. Used new bolts (stock nissan) to fix to chassis. I hope it holds good now. Xterra owners please note - to tow /tug as much as possible from the back. - front tow points need a lot of time to fabricate good ones and fix them.prefer 10mm steel atleast - any other suggestions or experiences welcome. 1 Link to comment Share on other sites More sharing options...
Frederic Posted September 9, 2020 Report Share Posted September 9, 2020 Have a look below. That looks like a very good set, and you can get your local fabriactor to make them the same. Don't forget to use high tensile bolts (8.8 or 10.9) when bolting it to the chassis. https://www.thenewx.org/threads/mps-habitat-offroad-front-recovery-point.239538/ pecifications: Thick, 1/2" steel construction Precision laser cut for perfect fit Fully welded Gusseted for additional strength Utilizes 3 frame mounting holes Grade 10.9 hardware included Black powdercoated finish Accepts 3/4" D-ring shackle Sold as a pair Made in the USA 4 "Go as far as you can see; once you get there, you'll be able to see further." Link to comment Share on other sites More sharing options...
Chaitanya D Posted September 9, 2020 Report Share Posted September 9, 2020 Thanks @Frederic, yes I have got them fitted with high tensile bolts. 1 1 Link to comment Share on other sites More sharing options...
