Pajero Gen4 offroad tire size
2 minutes ago, Baskaran P.R said:
I have Rubbing issue on my left wheel, I was thinking of trimming the bumper.  Is that will help?
Which size tires you have?
  • 1 month later...
On 1/31/2021 at 9:17 AM, Frederic said:
Check during installation if there is any running while steering completely left or right. On Vanessa her Pajero we have put a 2inch spacer to have slightly wider center of gravity.
@FredericIncreasing overall tyre diameter by more than 2% of the stock ones need speedometer and odometer calibration to be done? What else to be considered?
You can use the following website to determine if you are changing more than 2%:
https://tiresize.com/tyre-size-calculator/
As you can see in below example, the overall diameter in this case remains the same:
So you can input the data of the tyres you have now, and see how much difference you'd get by changing rim and/or tyre type.
  • Thanks (+1) 2
As in the attached file it goes beyond 2%. As you suggested already will fix wheel spacers. Some sites says already there might be 2-5% variation on speedometer and odometer from OEM. So if we add more to it, calibration of these are absolutely necessary or can manage with out that?181C638B-1341-473B-8C22-9C2F304C6C07.png.7bef25b26073b4e20f7b5ca2270c9fe5.png
I don’t think a 265/65/18 will fit without wheel spacers and might rub against the inner fenders. You’ll need to test it. @Vanessa8580 has Yokohama 265/60/18 and these fit fine.
Recalibration of odometer and speedometer: I don’t really see the benefit or need of doing that.
  • WOW (+2) 1
@Lakshmi Narasimhan if you are looking to install bigger profile tyres, I would suggest to change the rims to 17 inch and go for 265/65/R17. This will not cause rubbing issues and give a better footprint on the sand.
Else you can go the spacer route as Fred suggested, but before doing check if it affects the warranty.
  • 2 weeks later...
I have got 2” lift and upgraded to 265/65R17 by changing RIMs, even though its not touching theres barely 1-2 mm gap. While driving also no problem so far, need to check while on off-road if its ok or need to trim the bumper.
Thank you all for your suggestions.
I guess it should work perfectly, as I got a 2 inch lift as well with 265/70/R17 ATS tire and it's working fine so far... before the lift I had issue with the increased tire size as it used to hit the fender body during off-road but after the lift it has worked well in the last 3 drives for me.
  • 4 weeks later...
On 3/28/2021 at 11:10 AM, Lakshmi Narasimhan said:
Thank you all for your suggestions. Attached pics l!!!
Looks really good!
Are those Geolandar A/T G015's? If so, what pressure can you safely run them down to? 12?
