Afternoon Fewbie Plus Desert Drive - Lisaili " the loop II"- Dubai - 6 Feb - 2022
M.Seidam
Pre drive important information
Dear friends
In the second part of this loop drive " the loop II " i choose the mystical desert of lisaili and its outskirts from Murqab east up to the "middle earth" south and south west and back north to Lisaili proper. if you have a close look to the details on the map you can imagine the diversity of this terrain from super technical to the flat track and all what could be in between.
if you sign for this drive please its highly recommended the following points to be taken in consideration for the at most safety desired :
  • make sure your vehicle is at its optimum condition with all fluids and lubes been checked for any leaks and topped up.
  • please check you tow recovery points and its integrity.
  • check your spare tyre size and its condition and make sure you have the proper tools needed specific for your spare tyre change.
  • check your offroad  gear and that its tied up not loose.
  • please don't forget to come with two fully charged and programmed radios or a car charger available for it.
  • this drive may induce a motion sickness to some individuals prone to that such as children and persons whom are known to experience it . so please make the safest choice for them.
  • this is an afternoon drive that is planned to end at the sunset time , however prepare your self for some delay in case .
This drive is organized in full compliance with the COVID19 guidelines. We expect every member that joins this drive to go through below information and strictly follow these guidelines in order not to jeopardize someone's health, and to ensure we can keep organizing these drives safely.
MUST READ AND TOTALLY AGREE:
Drive Details
Level:  Fewbie plus and above
When:  6 Feb 2022, Sunday
Meeting time: 14:00  (SHARP - Without any exceptions)
Starting Point: https://goo.gl/maps/WHstoXFZbq8Ud9a98
Approximate finish time: 18:00
THIS IS A COMPRESSOR ONLY DRIVE. WE WILL END THE DRIVE AT A POINT WHICH IS NOT CLOSE TO AN AIR LINE. IF YOU DO NOT HAVE A COMPRESSOR, PLEASE DO NOT SIGN UP FOR THIS DRIVE. IF YOU ARRIVE AND HAVE NO COMPRESSOR YOU WILL NOT BE ALLOWED TO JOIN THE DRIVE
LIMITED SPOTS AVAILABLE:
  • Limited to 10 Fewbies plus and above drivers. RSVP will close on Thursday -  6 pm00000
    • If the RSVP is full and you wish to join, please add your self on the wait list option.
Please RSVP on Below Calendar:
  • Gaurav changed the title to Afternoon Fewbie Plus Desert Drive - Lisaili " the loop II"- Dubai - 6 Feb - 2022
Dear friends
@Gok Krish @Davie Chase @Pacific @luwaimn @Daniel Rodas @Daniel Yang @Naim Aoun @Fabien Monleau @James Thorn
good day and hope you are all ready for Sunday afternoon 2 pm sharp for the loop II . I have fixed the meeting point please refresh and you will find it in this drive topic above and calendar RSVP as well.
this drive is going to be a demanding one entraining full concentration and undivided attention so get enough rest before you come as we are going be crossing a diverse terrain more than 50 % is technical and super technical at some sections.
check the points of recommendation above in the drive topic  and please  make sure it’s all done .
Can’t wait to meet you on Sunday afternoon .
cheers 🙏
Seidam
  • Like (+1) 5
7 hours ago, M.Seidam said:
Dear friends
cheers 🙏
Seidam
Hi @M.Seidam I am ready in morning drive with Ale, so will withdraw my name. See you next time.  Thank you.
and who will calm us down in case of over excitement 😂 .. kidding off course , have fun dear see you in Loop III 😉
Good one 🤗🤗
Dear @Pacific can I ask you please to remove yourself from the RSVP 😊 unless you change your mind , as your name still on RSVP
Hi @Lucky sAm and @Reggie Landicho please confirm joining the drive so will add you to the drive as it’s your first drive as I see on the system
@Pacific I have removed you from the RSVP as per your last info above 🙏
Sorry for being late, thanks for doing the needful. 🤗
Doc I removed my name in the WL, I was accepted in Shaaz drive.
thanks as always.
Enjoy!
