Morning Fewbie Desert Drive - Nahil to Solar Park - AD/DXB - 17 Feb 2024
DRIVE DESCRIPTION
Welcome to Carnity Off road Club Fewbie drive, meeting at Nahil Abu Dhabi and ending at Solar Park in Dubai.
This will be a longish drive across the two emirates so please ensure you bring plenty of water, snacks, smiles and enthusiasm with you. This Drive is not recommended for passengers that may be susceptible to car/travel sickness.
We request every member that joins this drive to go through the below information and strictly follow these guidelines, etiquettes and responsibilities.
DRIVE DETAILS
Level:  Fewbie and above
When:  17 February 2024, Saturday
Meeting time:   07:00 - Sharp (Without any exceptions)
Meeting Point:  https://maps.app.goo.gl/SoHMSaqi3nPWy3wH6
Approximate finish time:  11:00
Type of Car: Any proper 4x4 with front and back tow hooks and 8-10 inches of ground clearance.
Mandatory off-road gears: Tire deflator, tire pressure gauge, compressor, walkie-talkie radio, off-road flag, shovel, first-aid kit, Tow Rope, 2 Shackles and fire extinguisher.
LIMITED SPOTS AVAILABLE
  • This drive is limited to 10 cars only. RSVP will close on Friday - 12 PM.
  • Please withdraw your RSVP, if you find you are unable to join, so your spot can be taken by others in the waitlist.
  • If the RSVP is full, you can add your name to the waitlist, if an RSVP attendee removes themselves, you will be moved from the waitlist to the RSVP list as an attendee.
  • A convoy list will be sent out the day prior to the drive.
PLEASE RSVP ON BELOW CALENDAR
  • Gaurav changed the title to Morning Fewbie Desert Drive - Nahil to Solar Park - AD/DXB - 17 Feb 2024
Hi @Davie Chase
I tried to join the Fewbie drive with you :) , but could get the chance, I am on the waitlist :(
I have a confirmed slot in the Newbie drive with @Islam Soliman on Sunday, and I am happy to give my space to any newbie member if I got a chance with your drive on Saturday.
let me know if that is possible
Thanks
Dear Desert Wanders @Federico Galbieri, @Abdullah N, @Rafey Hashmi, @Mehmet Volga, @Benjamin, @Renier Venter, @Shaun J, @Robk, @frederic demolder, @Haneef Thayyil, @Mark B, @Aser, @Ahmed Farouk, @Dr Tanveer Ahmed, @Julien Recan, @Ahmed Wagdy and @Ali-M I have added all from the waitlist to tomorrows drive. As this is a large convoy, please go in and remove your RSVP if your plans have changed so that we can accurately put together the convoy order.
Thanks in advance, I will post the convoy order later this evening, we will be using Ch4 (446.081)
see you all in the Morning :)
  • Like (+1) 6
Please see the convoy order below for tomorrows drive
See you all bright eyed and bushy tailed in the morning
  • Like (+1) 8
Good morning @Davie Chaseim sorry but I’m going to have to pull outside the drive. I was really looking forward to this weeks drive.
I’ve come down with some illnesss in the last few hrs so we will see what the doc says 🤞
  • Sad (0) 1
