AudiDxb Posted November 9, 2010 Share Posted November 9, 2010 Audi Maintenance Procedures - Common Additional Services Audi Air Filter Replacement The air filter accumulates dust and debris and should be replaced to protect the engine and maximize fuel economy. For optimal engine performance and longevity, replace every 1 year or 25,000 kms. Audi Automatic Transmission Fluid Change Automatic transmission fluid becomes heat fatigued and accumulates moisture over time which can lead to automatic transmission damage if not serviced regularly. It should be replaced every 2 years or 50,000 kms. Audi Cabin Air Filter Replacement Over time the Cabin Filter(s) will accumulate dirt, pollen and debris which can leak in to the passenger compartment if left unchecked. They should be replaced every year or 25,000 kms. Audi Coolant Replacement/Flush Engine coolant breaks down, gets rusty and becomes contaminated with debris from component wear over time and can cause engine or cooling system damage if not replaced every 2 years or 50,0000 kms. Audi Drive Belt(s) Replacement Drive belts crack and become glazed over time and can squeak or even break. They should be replaced every 75,000 kms. Audi Fuel Filter Change The Fuel Filter becomes restricted as it accumulates debris from filtering the fuel which, can lead to perfomance problems and early fuel pump failure. It should be replaced every 2 years or 50,000 kms in vehicles where it is replaceable. Audi Rotate Tires It is important to rotate the tires from front to rear every 8000-10,000 kms so that they wear evenly. This may not be possible on some vehicles because of directional tread design or rim size differences. Link to comment Share on other sites More sharing options...
AcidBurnSB Posted August 22, 2012 Share Posted August 22, 2012 Thanks. Easy to read no need to check service book for now. Link to comment Share on other sites More sharing options...
ghostrider Posted August 30, 2012 Share Posted August 30, 2012 thank i used this info 2 times didnt have to google. good job. Link to comment Share on other sites More sharing options...
