Morning Fewbie Plus Desert Drive - Nahel - Abu Dhabi - 14 Sept 2024
DP1011
DRIVE DESCRIPTION
Welcome to the Carnity Fewbie Plus Nahel drive. For those who have experienced Nahil, would confirm, Offering a Fast-paced drive with ridges, Criss-crossing, and bowls. Some extremely soft patches at times, and hence testing your skills of applying basics learned, at a faster pace. - Double check / Triple check your machines please, if any known issues even if minor, please refrain from joining this drive and pushing the car!
Co-passengers - I would highly advise against it, as summer times and we might end up having some unplanned delays, although the intention is to keep it under 4 hours and exit when it starts to get hotter. Certainly not more than 1 Co-passenger please.
Starting ON TIME is key and hence, The drive will Commence Sharp 10 minutes from the meeting time ie at 5.55am, hence Sign up ONLY if you think you can be at meeting point by 5.45!
DRIVE DETAILS
Level:  Fewbie Plus and above
When: 14 Sept 2024
Meeting time: 05:45 AM (SHARP - Without any exceptions)
Meeting Point: https://maps.app.goo.gl/uoPKsJH8NAUYKdnS6?g_st=ic
What to bring along: Loads of water, snacks (for yourself), smiles, face mask, rubber gloves, enthusiasm, and willingness to learn.
Approximate finish time: 8.30 am
What to bring along: Loads of water, snacks (for yourself), smiles, enthusiasm, and willingness to learn.
Mandatory off-road gears: Tire deflator, tire pressure gauge, compressor, walkie-talkie radio, off-road flag, shovel, Rope, 2 Shackles, first-aid kit, and fire extinguisher.
LIMITED SPOTS AVAILABLE:
  • This drive is limited to 10 cars only. RSVP will close on Friday - 9 AM.
Please RSVP on below calendar
1 hour ago, Abhilash Kottakkal said:
@DP1011 I breaking in to destroy the all jeep drive. My first fewbie plus drive..I will push as much as I can...
Doing first FB+ in Nahil isn't a good idea tbh, especially after the holiday gap. You can test your skills in other areas first for safety reasons.
Nahil with steep climb, soft ridges, big bowls can be overwhelming.
  • Totally Agree (+2) 4
@Gaurav I understand the risk the inexperience might cause and safety is of prime importance @DP1011 thank you very much  for the call..I will try after gaining much more experience...
On 9/9/2024 at 7:27 PM, DP1011 said:
So far its an All JEEP Convoy😅💥! @Zed @Nizar Shawwa @Aser @Mahmut @Brett Eicher @RiadJL
bro @DP1011 sorry to burst the bubble, but da Jeep got transmission code error, so i'll be the odd one out with LC. I will camouflage it with a Jeep flag tho 😂
  • Haha (+1) 2
  • Sad (0) 1
RSVP CLOSED.
Dear JEEPERS & IMPOSTERS 😛  ( @Aser @Brett Eicher @Mahmut @Nizar Shawwa @Marek @RiadJL @Alexanderrr  @Zed )
Below Convoy order - you all have driven earlier with me and hence I will not re-iterate about start time of the drive :) 5.55am we leave. Please factor in every possibility of Fog and leave accordingly to be on/before time !
The meeting point is :  https://maps.app.goo.gl/uoPKsJH8NAUYKdnS6?g_st=ic ( updated in the description)
We will use Channel 2 : 446.031.
See you tomorrow 5.40 DEFLATED AND FLAGGED UP.
  • Haha (+1) 3
