stock lights to HID conversion set lights optima 2011
raielp
thanks basim:
so the issue here is to cut the wire from the stock OEM and connect it to the HID wires. although i did have tried converting an H7 bulb to HID set but those set did not need of cutting wires, where the bulb can easily be removed and the HID wire kit can easily be inserted into the socket as i did on my sorento before
