Broken Mirror
amitaj
Its easy. Buy the new side mirror first.
Now to install the new one, you got to remove the broken side mirror. There is a plastic cover inside the car which is covering the mounting screws. Remove that first.
Unscrew all the mounting screws of the side mirror. Be careful when you do that, and make sure you dont loose any screw, as you will be needing them all to fix the new mirror. Along with the screws, there will be an electric plug as well. Just deattache the same when you are removing the mirror.
After removing all the bolts, install the new side mirror on the door, and tense all the bolta back. After you tighten all the bolta, attach the electric plug again to the space provided. Now, put back the plastic cover to the original space. You are good to go now!
  • 4 months later...
