Suneer
AC Grinding noise-FX50
8 posts in this topic
Hi All, I am new to this form. I have FX50s 2009 Model. The problem is when i am at signal or at stop i can hear AC making a grinding noise and makes extra load on the engine. While driving i don't notice much. Any one had similar experience? Thanks.
It must be coming while driving too, but with road and engine noise you might not be hearing it. Slight extra AC load on engine due to low rev while idle is normal for all cars especially in summer months, as AC work harder and frequent but what grinding noise you get, can you attach an audio file here.
Suneer likes this
There could be leaking compressor gas and making some grinding noise, and AC cooling quality also deplete as treks as if A/C still working with same as before quality?
Suneer likes this
Any noise coming from the compressor is bad, but mechanical noises can sometimes be mimicked by a drive belt that is dry, sticky, or damaged. So, if the compressor is damaged and making a noise, it is likely that the system will not work as well as before.
It may be worth the trouble to pop around to Barry's garage to let him check out the belt, and/or tensioner pulley(s), especially if the A/C system is working as well as it did before the noise started.
Suneer likes this
18 hours ago, treks said:
Does the A/C still work?
Hi. Thanks. Yes, AC is working and cooling fine. Just that it makes a grinding noise and feels like car wants to move when i am at signal or on brakes. Feels like engine is having extra load to move.
Hi All, Many thanks for all yours quick responses. Does any one know good garage in Abu Dhabi or Dubai?
    • Dreamland Aqua Park + Lunch on 28 April 2017
    • Fake Chinese iphones
    • City Overdrive Underground Party
    • The diagnostics game
    • Fancy owning your own Veyron?
    • Desert / Mountain drive and overnight camping - 21 - 22 April 2017
    • Your driving bucket list
    • Movie Night - Fast and Furious 8 - 14 Apr 2017
    • Secret Silk Route Drive for Newbie/Fewbie - 7 April 2017
    • BMW D-Drive
      BMW D-Drive
    • Best birthday ever
      Best birthday ever
    • Scenic drive to Jabal Jais - highest point in UAE - 31 Mar 2017
