UAE'S MOST ENGAGING CAR SITE
Sidshk
Power Steering Oil
Thanks @treks for lovely find. Worth reading
Extract from above link:
  • Mitsubishi Diamond SP-II and SP-III— Mitsubishi fluid.
is it same as image i shared, so i can take it
Yup it should be good, just check what exact spec mention in your owners manual before buying SP-II or III.
  • Thanks 1
Does any one have E-Manual of Pajero ??
Which year model you have?
2008 LWB 3.00 Ltr
Check the first pic look similar to your age Pajero? As I am not sure if its exact 2008 owners manual or not. Hope it helps.
Best is go to Habtoor with car registration card and ask for "Genuine MITSUBISHI Power Steering Fluid".
http://www.mitsubishi-motors.bg/uploads/files/8_file.pdf
Go to refill capacities Page 9-16
  • Thanks 2
Fluid type
Use “Genuine MITSUBISHI Power Steering Fluid”
or “ATF DEXRON III/DEXRON II”.
Edited by Sidshk
Oil eh, always ruffles the feathers around here! :D
If it was for the transmission I'd say stick with OEM and all this discussion is kinda pointless, since its for the power steering. Which in this Pajero is basically nothing but a hydraulic pump and ram. And the manual itself as posted says its fine to use Dex II or III, so really not that much of an issue. Much ado about nothing!
Yes some cars require fancy pants oil even for steering but this is not the case here. Any reasonable brand Dex II or III should be fine, as long as its not made from old samosa and paratha ghee refined in a shed in Ajman.
  • Haha 1
4 hours ago, Sidshk said:
Fluid type
You read what you wanted and I read what I wanted, that's all I have been explaining since beginning.
