Sidshk Posted September 26, 2018 Report Share Posted September 26, 2018 Does Pajero 2008 has Chain instead of Belt ? can any one clarify Link to comment Share on other sites More sharing options...
shadow79 Posted September 26, 2018 Report Share Posted September 26, 2018 mitsubishi's mostly have engine with belts only some recent models came with chain you can spot them easily by just looking at the timing cover if its plastic then its belt as chains usually have a single metal covering with small bolted and siliconed covers usually for tensioners and other things Link to comment Share on other sites More sharing options...
Sidshk Posted September 26, 2018 Author Report Share Posted September 26, 2018 10 minutes ago, shadow79 said: mitsubishi's mostly have engine with belts only some recent models came with chain you can spot them easily by just looking at the timing cover if its plastic then its belt as chains usually have a single metal covering with small bolted and siliconed covers usually for tensioners and other things Possibility of any image ? cause for lame person its very difficult to understand Link to comment Share on other sites More sharing options...
shadow79 Posted September 26, 2018 Report Share Posted September 26, 2018 (edited) dont have any pajero 2008 in for now but if you can post the area behind the clutch fan of your car then we can input something....as far as i know the diesel one has the chain and the petrol one is having belt.... Edited September 26, 2018 by shadow79 more info Link to comment Share on other sites More sharing options...
Gaurav Posted September 26, 2018 Report Share Posted September 26, 2018 I'm over 90% sure that 2008 Pajero came with the timing belt, as in Mitsubishi majority vehicles have timing belt other than some specialized one like Evo and Eclipse came with a chain in few years only. 1 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
Adnan Khan Posted September 26, 2018 Report Share Posted September 26, 2018 (edited) I know for sure 2009 does not have timing chain. Because i changed it 6 months back. Edited September 26, 2018 by Adnan Khan 2 Link to comment Share on other sites More sharing options...
Barry Posted September 27, 2018 Report Share Posted September 27, 2018 100% it’s a belt. I don’t know about the eclipse, never worked on one but as @Gaurav said, the later Evos had a chain. In such a case, the chain still needs maintenance at 60k. It’s not a case of change belts but chains are always ok as many people think. Chains stretch, especially on newer cars with VVT where there is extra strain on the chain. A stretched chain can easily see you with bent valves or broken rockers. 1 Link to comment Share on other sites More sharing options...
