Srikumar Posted August 4, 2019 Report Share Posted August 4, 2019 Hi I recently installed a Digital Music Changer in my 8th gen Honda Civic. This is mainly to connect a USB / AUX / Memory Card to the existing head unit. I have been using it a little over a month with the AUX connection. Yesterday I inserted a memory card for the first time. While it was working fine in the morning, by evening it stopped working and even the AUX connection was not working. I tried restarting the car, disconnecting the Digital Music Changer from the head unit. But to no use. Even this morning when I started the car it was not working, and suddenly after an hour it started working. In the afternoon it again stopped working. Though it's a minor issue, but i spent AED 200 for the unit and incase i have to replace it was wondering what i need to check to avoid this the next time. Any suggestions? 2 Link to comment Share on other sites More sharing options...
Frederic Posted August 4, 2019 Report Share Posted August 4, 2019 Can you share some details on the unit itself ? Was the wiring done properly ? I mean soldered and not just twisted into each other ? Or is this a plug and play thingy ? Maybe the unit is sending out a distorted signal (too loud) for the headunit and this input goes into safety. 2 "Go as far as you can see; once you get there, you'll be able to see further." Link to comment Share on other sites More sharing options...
Srikumar Posted August 4, 2019 Author Report Share Posted August 4, 2019 @Frederic it's a plug and play device. The end connection is similar to a desktop VGA cable end, but only wider with more pins. I will try to send the diagram for you to have a look. 2 Link to comment Share on other sites More sharing options...
Gaurav Posted August 4, 2019 Report Share Posted August 4, 2019 If you recently bought this, which I think you must have after your recent civic purchase, just go to the shop and complain. If it's old then DIY debugging is a good idea. Which brand is that, share some model info so we can dig into it. 2 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
Barry Posted August 6, 2019 Report Share Posted August 6, 2019 Take it back and throw it at the guy and say, hey you sold me shit 1 1 Link to comment Share on other sites More sharing options...
Gaurav Posted August 6, 2019 Report Share Posted August 6, 2019 Looks like he bought it from Dragon Mart without a receipt or even a business card. When he went back to complaint all the shops and faces look same. That's why he is not replying here 2 1 1 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
Srikumar Posted August 6, 2019 Author Report Share Posted August 6, 2019 I actually got it done in Deira Naif area and unfortunately have not had the time to visit the area yet. But in the meanwhile, I was able to isolate the issue to my SD card only and I was reading somewhere (cant recollect where now) that if in the SD card there are more than 99 songs in a single folder this error can happen. So would be segregating the songs in the folders and giving it a try. 1 2 Link to comment Share on other sites More sharing options...
Frederic Posted August 6, 2019 Report Share Posted August 6, 2019 6 minutes ago, Srikumar said: I actually got it done in Deira Naif area and unfortunately have not had the time to visit the area yet. But in the meanwhile, I was able to isolate the issue to my SD card only and I was reading somewhere (cant recollect where now) that if in the SD card there are more than 99 songs in a single folder this error can happen. So would be segregating the songs in the folders and giving it a try. Yes that’s a good remark. Also check if the unit accepts MP3 only or not. You might have other audio formats on that cards like M4a, AAC, Wmv, etc... that the unit is having difficulty with. 2 2 "Go as far as you can see; once you get there, you'll be able to see further." Link to comment Share on other sites More sharing options...
adil Posted August 7, 2019 Report Share Posted August 7, 2019 Yes remove all file format whose encoding are not readable by that system as it will hang and confuse after every track. Link to comment Share on other sites More sharing options...
desertdude Posted August 7, 2019 Report Share Posted August 7, 2019 On 8/6/2019 at 6:51 PM, Barry said: Take it back and throw it at the guy and say, hey you sold me shit A little too early to be drinking grandpa's cough medicine 1 Link to comment Share on other sites More sharing options...
