Naim Aoun Posted August 18, 2022 Share Posted August 18, 2022 Looking into buying a hydraulic jack and came across this forum. Does it have to be a Low Profile? Do you think this popular one is suitable? BIG RED T82012 Torin Hydraulic Trolley Service/Floor Jack with Blow Mold Carrying Storage Case, 2 Ton (4,000 lb) Capacity, Red: Buy Online at Best Price in UAE - Amazon.ae There is a 12V electric one as well for around 400 UAE? Do you think it is worth it? 1 Link to comment Share on other sites More sharing options...
Frederic Posted August 19, 2022 Share Posted August 19, 2022 19 hours ago, Naim Aoun said: Looking into buying a hydraulic jack and came across this forum. Does it have to be a Low Profile? Do you think this popular one is suitable? BIG RED T82012 Torin Hydraulic Trolley Service/Floor Jack with Blow Mold Carrying Storage Case, 2 Ton (4,000 lb) Capacity, Red: Buy Online at Best Price in UAE - Amazon.ae There is a 12V electric one as well for around 400 UAE? Do you think it is worth it? Hi @Naim Aoun Ideally it should be a low profile, this will help to get it installed underneath the vehicle. The model you posted (big red) would do the job, but if you find a model with a wider footprint that would be even better. JZX has decent models as well. The 12V electric one is..... question mark and might fail just at the time you need it. I would not go that direction. 1 "Go as far as you can see; once you get there, you'll be able to see further." Link to comment Share on other sites More sharing options...
Waqas Parvez Posted August 19, 2022 Share Posted August 19, 2022 hi @Frederic i went to jzx yesterday the biggest problem was it does not come with a carry case,do you any other reliable ones with the carry case? 1 Link to comment Share on other sites More sharing options...
Sunil Mathew Posted August 19, 2022 Share Posted August 19, 2022 Jzx 2 ton comes with carry case..i just bought one @Waqas Parvez The 3 ton is too big, but has lot of lift height, and no box..were you looking at the 3 ton? 1 Link to comment Share on other sites More sharing options...
GauravSoni Posted August 19, 2022 Share Posted August 19, 2022 For me JZX has an issue of leaking oil. No matter how many times I top up… make sure right screw, keep it upright while in boot.. after about 4 to 5 days, it losses oil and does not hold weight… 2 Link to comment Share on other sites More sharing options...
Hisham Masaad Posted August 19, 2022 Share Posted August 19, 2022 After long research I ended up buying the bottle jack. Very good saving space, and light weight. Had the electric one @Naim Aoun sometimes was not working when required to, as @Frederic mentioned, for silly reason, the sand was going inside the switches. 1 1 Link to comment Share on other sites More sharing options...
Thomas Varghese Posted August 19, 2022 Share Posted August 19, 2022 4 hours ago, Sunil Mathew said: Jzx 2 ton comes with carry case..i just bought one @Waqas Parvez The 3 ton is too big, but has lot of lift height, and no box..were you looking at the 3 ton? When its time to fix a pop out and if I'm in the convoy its always my 3 ton jack which eases the situation. 1 Link to comment Share on other sites More sharing options...
Looper Posted August 20, 2022 Share Posted August 20, 2022 (edited) 14 hours ago, Waqas Parvez said: hi @Frederic i went to jzx yesterday the biggest problem was it does not come with a carry case,do you any other reliable ones with the carry case? For my 2.5 ton jack I use a long tool bag from Speedx and it fits perfectly. Edited August 20, 2022 by Looper 2 don't drive like its your last one. Link to comment Share on other sites More sharing options...
Hisham Masaad Posted August 21, 2022 Share Posted August 21, 2022 Bottle jack did well today 4 2 Link to comment Share on other sites More sharing options...
M.Seidam Posted August 21, 2022 Share Posted August 21, 2022 On 8/19/2022 at 7:19 PM, GauravSoni said: keep it upright while in boot. That’s true and it’s recommended in the leaflet to keep it position it as such otherwise it will leak sooner or later 2 Link to comment Share on other sites More sharing options...
