javed Posted February 29, 2012 Report Share Posted February 29, 2012 cruise control stopped working.Can i fix this myself or a mechanic is needed for work like this? Link to comment Share on other sites More sharing options...
Sharky Posted March 4, 2012 Report Share Posted March 4, 2012 What year / model of Rangie dod you have? One of my Disco IIs cruise control stopped working and it was going to cost around AED11K to fix it as it is also related to the "Three Amigos" lights issue ..... not worth it really unless you really use it for long distance driving. Cheers, Sharky Link to comment Share on other sites More sharing options...
Prufster Posted March 22, 2012 Report Share Posted March 22, 2012 Hi, Mine is not working either and the problem is the vacum pump. For what I know it is quite easy/cheap to repair it.... Link to comment Share on other sites More sharing options...
Gaurav Posted March 22, 2012 Report Share Posted March 22, 2012 In my Range Rover cruise control is also not working or sometimes working after many hits on crusie engage button and then slowly it loses the speed. Any idea how i can fix that? or do i need new vaccuum pump for cruise control? Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
KimChance Posted September 8, 2013 Report Share Posted September 8, 2013 It doesn't work every time, but there is a little rubber vacuum hose that sometimes deteriorates causing leakage and loss of function. Replacing the hose is a very cheap fix if that is what the problem is. I put up with a lack of cruise control in a Disco 2 for three months, thinking it was something electrical and complicated only to find I could fix it in 5 minutes with a spare bit of rubber tubing. Link to comment Share on other sites More sharing options...
