Cruise control stopped working.
javed
What year / model of Rangie dod you have?
One of my Disco IIs cruise control stopped working and it was going to cost around AED11K to fix it as it is also related to the "Three Amigos" lights issue ..... not worth it really unless you really use it for long distance driving.
Cheers,
Sharky
  • 3 weeks later...
In my Range Rover cruise control is also not working or sometimes working after many hits on crusie engage button and then slowly it loses the speed.
Any idea how i can fix that? or do i need new vaccuum pump for cruise control?
  • 1 year later...
It doesn't work every time, but there is a little rubber vacuum hose that sometimes deteriorates causing leakage and loss of function. Replacing the hose is a very cheap fix if that is what the problem is. I put up with a lack of cruise control in a Disco 2 for three months, thinking it was something electrical and complicated only to find I could fix it in 5 minutes with a spare bit of rubber tubing.
