romelind Posted June 18, 2011 Report Share Posted June 18, 2011 the dipper light is not working dose this light have a separate wire or fuse that i can check? Link to comment Share on other sites More sharing options...
newtoni Posted June 22, 2011 Report Share Posted June 22, 2011 Yes it has a separate fuse, if fuse is fine you need to doubt at switch in the steering wheel. If some sand reaches there it stop working. Open the wheel and clean and refix will solve this issue. Link to comment Share on other sites More sharing options...
