virkant Posted March 22, 2012 Report Share Posted March 22, 2012 battery light flickers checked the alternator and battery both are working. What can i do to stop the flickering. Link to comment Share on other sites More sharing options...
Amalik Posted March 24, 2012 Report Share Posted March 24, 2012 This means for sure either you have loose terminal or calc deposit on terminals. Remove both battery terimal and pour some hot hot water on both terminals and socket, clean it nicely and wait till it dries, apply little grease and refix it tightly. If still you have flickering after above excersise, then that means your alternator is on the way of expiring and soon you will be stranded on road side. If that happen, dont panic and switch off all lights, ac, music etc and you will be able to drive home atleast. As if battery is good it holds enough charge to keep your car running for few hrs w/o any other electrical overheads. Link to comment Share on other sites More sharing options...
sh8ker Posted September 25, 2012 Report Share Posted September 25, 2012 wow. that is helpful malek. my battery is more than ayear old now. which battery model should i buy? my rolla is 2011 model btw! thanks! Link to comment Share on other sites More sharing options...
ahsaan Posted September 26, 2012 Report Share Posted September 26, 2012 Yeah i wanna know the same what battery i should buy. Link to comment Share on other sites More sharing options...
Amohd Posted October 7, 2012 Report Share Posted October 7, 2012 i the terminal is loose then it can be fetal get a professional to look at the car. Link to comment Share on other sites More sharing options...
tambi Posted November 9, 2012 Report Share Posted November 9, 2012 anyone's got instructions on how to change the battery? Link to comment Share on other sites More sharing options...
virkant Posted January 31, 2013 Author Report Share Posted January 31, 2013 battery light was the culprit not the battery so fixed it. Link to comment Share on other sites More sharing options...
