Crank shaft issue
GIC
Hi, had it checked on the computer in a garage.Later he even changed it.Bought an aftermarket part for 180/-.
Just worked for 1 day, Next morning again the car wont start.
Quote
Crankshafts generally do not cause cars not to start. Going by the price of the part you mention, I'd say that they replaced the crankshaft sensor, which is the thingamajig that creates the ignition spark. If so, the problem was clearly not related to the crankshaft sensor, and you should find a proper mechanic next time.
Edited by treks
4 hours ago, desertdude said:
Damn should have bought a BMW if I knew the parts were that cheap, entire crankshaft for just 180dhs :D
...and you even get the fitment for free:-D
seems it also could be the wiring to the ecu if you have changed to a known working sensor...
if you can show what was the initial computer diagnosis that would also help to the right direction...
