maanav Posted July 19, 2011 Report Share Posted July 19, 2011 i want instruction to remove and replace the rear view mirror that is inside the car. Please advise to how i can do this Link to comment Share on other sites More sharing options...
yaata Posted August 7, 2011 Report Share Posted August 7, 2011 Remove the overhead control panel control module and Pull inside the rear view mirror down at one side FYI The inside rear view mirror is held by spring tension Now disconnect connector from overhead control panel control module and remove inside rear view mirror. For installation do the same thing in reverse order. Link to comment Share on other sites More sharing options...
