ibaadat Posted August 22, 2011 Report Share Posted August 22, 2011 The Automatic Slip Control System (ASR) is locked on and no one can repair it as i have checked with the mechanics in dubai as well as sharjah. When the ASR System is on, the car's acceleration is greatly reduced. Link to comment Share on other sites More sharing options...
kumar Posted August 26, 2011 Report Share Posted August 26, 2011 Have you check the electrical side of it? Usually these paranormal lol activity happen due to some switch, socket, wiring, sensor, relay or fuse failures. If yes then simply you have to replace the whole system and i am sure with modulator it will be bomb expensive. Try sourcing in scrap in shj for less. Link to comment Share on other sites More sharing options...
