Mohit1 Posted December 12, 2017 Report Share Posted December 12, 2017 Hello All, I am a new user here, just registered was referred by Rahimdad. So here is the issue that I am facing with my car, every morning when i start the car it misfires until the temperature becomes adequate. I changed spark plugs twice, spark plug cables are ok as tested by mechanic. there was no engine light on dashboard until today morning when trying to check vacuum for air suction, while checking if there is air suction happening properly check engine light came on. No computer diagnostic were done so far as check engine light or any other light never showed on dashboard. Car runs perfect once temperature is fine . Also got cylinders tested with power loss which also is not there. I had doubts with o2 sensor or mapping sensor but mechanic just wants to try different stuff that I am not convince on. removed the mapping sensor and car switched off immediately, .... Please advise if anyone has any idea about the issue. Link to comment Share on other sites More sharing options...
Barry Posted December 12, 2017 Report Share Posted December 12, 2017 2 spark plug changes and randomly suggesting changing parts with no diagnostic checks? Time to find a new mechanic. Just because the check engine light isn’t illuminated doesn’t mean there are no codes stored so start with a basic code scan to see what comes up. Run some live data, check MAF and MAP values and long and short term fuel trims and you’ll have an idea of what’s going on. Basic stuff really that any decent mechanic will do before changing anything. 2 Link to comment Share on other sites More sharing options...
Mohit1 Posted December 13, 2017 Author Report Share Posted December 13, 2017 Thanks Barry, the thing is that i went to a couple of mechanics in al qusais and Sharjah all want me to leave the car with them over night to see the issue when car is cold. I dont get convinced because why do they need car to be cold for diagnosis when computer checks generally figures out regardless of temperature. i want diagnosis in front of me, else they will try something, obviously before the car is delivered it will kept on and nothing is wrong when car is hot ..... so next day i may end up having same issue ... I went to another guy who has a computer he doesnt mind running diagnostics but insisted that i should leave the car overnight and he will run test in morning. I am doubtful of o2 or mapping sensor voltages, lastly just a dirty throttle body funny thing by the time i reached home CEL was gone Link to comment Share on other sites More sharing options...
treks Posted December 13, 2017 Report Share Posted December 13, 2017 Sometimes, and depending on the fault, some TDC's will reset automatically when the ECU senses that the fault is no longer present, such as the fault you created when you disconnected vacuum lines. As @Barry said, find a decent mechanic that can do a proper scan of the car's fault memory, because sometimes, some faults can be stored as "pending" codes that need to be registered by the ECU for a set number of times before a CEL light will come on. Link to comment Share on other sites More sharing options...
Mohit1 Posted March 27, 2018 Author Report Share Posted March 27, 2018 Hi everyone, So this is what I did with a car and it works perfect now -Cleaned Injector they were not flushing petrol in uniformtiy - cleaned lambda sensor was also quite dirty problem unresolved - Computer showed throttle body errors cleaned it did not help changed it to a new one, did not help error was still the same so had to try another throttle body... this time it worked and misfire went off however, while throttle body was being fixed i was planning to check on gasket manifold leaks..... did a sealant ... Coz the problem was back i went to garage and got the sealant pasted nicely .... to my luck my car's performance is perfect now.. there were couple of issues - injectors -lambda sensor -throttle body -gasket manifold leaks Just in case this helps any one in future 1 Link to comment Share on other sites More sharing options...
Rahimdad Posted March 27, 2018 Report Share Posted March 27, 2018 Fthanks or sharing @Mohit1 this is the true car community spirit. I have seen lot of time people solving their problems and not posting the solution. Well done Bhai. Link to comment Share on other sites More sharing options...
Ren13 Posted March 27, 2018 Report Share Posted March 27, 2018 well done @Mohit1 got to learn something new regarding the duster repairs. will surely keep in mind for further trouble shooting solutions. Link to comment Share on other sites More sharing options...
Mohit1 Posted March 29, 2018 Author Report Share Posted March 29, 2018 Thanks to Carnity where there is forum like a family then just Business :).. I am sure we all can sometimes recommend each other here and there. 1 Link to comment Share on other sites More sharing options...
